WiFi weather station
A project log for NodeUSB- ‘Eat your own dog food’ WiFi IoT DevKit
NodeUSB is a tiny, low cost $9, WiFi ready, ESP8266 USB dev kit for Internet of things, it comes with NodeMCU pre-installed
michael-wenMichael Wen 05/10/2015 at 23:490 Comments
Steps to make a WiFi weather station:
  1. soldering 90 degree 2.54mm headers onto NodeUSB
  2. Soldering si7021 module on 2.54mm header
  3. If you want to add barometer, Use quick connect wire to add bp180 module
  4. put into case closures
  5. put in USB power adapter
Here are the pictures:
