Global Safe NET
A Protective NET of observers who can detect wind flows tempest approaching climate changes, and others flaws in global scale
The primary part of the project relay on the flying autonomous module ( flaumo ) an sphere of robust construction holding equipament ( raspberry pi ) able to measure conditions on the ambient nearby like wind speed, air thickness, polution levels
  • 1 × ADAFRUIT ULTIMATE GPS BREAKOUT - 66 CHANNEL W/10 HZ UPDATES GPS for positioning and geolocalization of the module
  • 1 × AirPi Kit v1.4 - Raspberry Pi weather shield A shield to hold some of the sensors
  • 1 × Raspberry Pi Modelo A + Main CPU unity for the module, gather sensors info as flying controls and stability
mnunesvsc wrote 03/23/2015 at 18:34 point
Thankyou zakqwy, its an start i will detail all sensors fully
zakqwy wrote 03/23/2015 at 18:03 point
The devil is in the details on the instrumentation; pollution (for example) takes many forms, and depending what you want to measure you may find accurate data difficult to obtain. More info?
