SubPos Receiver
A project log for SubPos Positioning System
A "dataless" Wi-Fi positioning system that can be used anywhere GPS can't.
BleckyBlecky 01/31/2016 at 10:170 Comments
I have released the sources for a receiver module which works with the ESP module - https://github.com/subpos/subpos_receiver
It's been tested on Arduino and the Teensy 3.2 as well as Energia and the Launchpad Tiva C (tm4c123).
For use with the ESP Wi-Fi Scanner Firmware - https://github.com/subpos/esp_wifi_scanner
