EZeeSample
Shelved this one to work on other things - kept for sentimental reasons
It is common to have to sample all plants within a set distance (eg 20m) of a transect line or a point. However, keeping within this distance is challenging, and errors in peoples estimation of distance can have a bnitg effect on overall results. Thus, we have a device held by one person who stays on the right track, and slave devices held by other people, which let them know when they're straying out of bounds. They can also record data with buttons on the slave devices, and possibly save locations with a GPS modeule in the main device. Poissible features: - Easily attach to a spray bottle, so that plants can be sprayed with dye to avoid double-counting, and have the point recorded simultaneously. - Display to show distance to base station - GPS tagging of locations - Ideally, a way of determining direction as well as distance, possibly to be displayed by the base station. - Cheap - slaves based of ATtiny85s to keep costs down - Other features as I think of them
Initial ideas:
  • Each slave will be equipped with a microphone and a speaker. Communication will be through a call/response sort of deal. I'll have to get some hardware built before I can experiment and figure out the best way to do this. I may need to add IR sensors to keep everything synced up...
  • Master will be in charge of recording a waypoint when any slave is clicked, as well as the distance to said slave, tyhe name of the slave and any other relevant data like current time etc etc.
  • Everything will have to be robust for use in the bush, and low power enough for long sampling trips. Solar charger anyone?
  • 1 × ATtiny85 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × Teensy-LC
  • 1 × IR LED
  • 1 × IR photodiode with high-pass filter
  • 1 × Speaker
View all 7 components
  • Sound output looking noisy
    johnowhitaker07/02/2015 at 09:27 0 comments
    I'm using a timer to toggle a pin on the ATtiny85. Was hoping for a nice square wave, but looks a little noisy:
    Should still do the job.
    NB this could also be because of my utterly hacky 'scope (https://hackaday.io/project/6511-cell-phone-oscilloscope)
  • ATtiny test code working, trinket has arrived!
    johnowhitaker06/18/2015 at 06:58 0 comments
    I finally got the ATtiny85 code behaving as I want. It simultaneously sends out an ultrasound beep and flashes an LED. I can now start writing code to detect these and estimate distance. The code uses the internal timer1 to do PWM, generating the required frequency without using up CPU resources. This is vital as it will need to do other things. I also have interrupt code for when a button is pressed and some other fluff, but for now this is all I need to test everything. Here is the code:
    #include <avr/io.h>
    #include <util/delay.h>
    #include <avr/interrupt.h>
    // write digital high or low to pin <pn> on port <prt> - good for arduino converts
    #define DIGIWRITE_H(prt, pn) prt |= (1<<pn)
    #define DIGIWRITE_L(prt, pn) prt &= ~(1<<pn)
    void initTimer(){
      //TCCR1 = _BV (CS10);       // for no prescaling
      TCCR1 |= (1 << CS10);       // PCK/2
      //TCCR1 |= (1 << CS11);      // uncomment the rest of these to lower the frequency to ~1Hz
      //TCCR1 |= (1 << CS12);      // look at ATtiny85 datasheet to see which bits scale the clock of timer 1 by what amount
      //TCCR1 |= (1 << CS13);
      GTCCR = _BV (COM1B1) | _BV (PWM1B);  //  clear OC1B on compare, we'll be doing PWM with the output directly toggling PB4 (OC1B)
      OCR1B = 80;                   // duty cycle (50%) = freq/2
      OCR1C = 160;                  // frequency (lower = higher frequency)
    }  // end of setup
    void main() {
        initTimer();
        //DDRB is the data direction register for port B - the io pins on the ATtiny85 are all in port B.
        //Each bit refers to one pin. 0 means input, 1 means output.
        DDRB = 0b00001000; //pin PB3 to output and PB4 + the rest to input for now(pins 2 and 3 on DIP ATtiny85)
        for(;;){
            DIGIWRITE_H(PORTB, PB3); //turn LED on
            DDRB = 0b00011000; //allow output on the speaker pin (PB4). This saves having to stop and restart the timer each time.
            _delay_ms(500);
            DIGIWRITE_L(PORTB, PB3); //turn LED off
            DDRB = 0b00001000; //turn speaker off
            _delay_ms(500);
    I program the chip with a bus pirate as detailed in a previous log, and I can then easily test it by turning on power from the bus pirate from a serial console. The uses of that tool continue to amaze :)
    Next in the TODO list is to hook up a mic + preamp to the teensy and see if we can detect sound...
  • Advice requested: Phone or Teensy
    johnowhitaker05/08/2015 at 19:42 0 comments
    The main base station (Master) needs to be able to time the delay between an IR flash and the arrival of an ultrasound pulse (my best idea for estimating distance). I was thinking of offloading some of the work to a phone by using the headphone jack as IO. However, the post on teensies made me wonder if detecting a 25kHz tome would be doable fast enough on a low cost arm processor. This would make the project more self-contained and probably cheaper... Anyone have thoughts on this, or experience detecting specific frequencies with a micro?
  • Begging for PCBs
    johnowhitaker04/27/2015 at 06:31 0 comments
    In this log I'll outline the PCB work I'll need to move this project along, as suggested in this HAD post, although the dog makes my case fairly eloquently already :)
    There will be two separate boards for this projects, which I'm going to call the master and slave. I'm not sure how I'll design the master board yet. It may be an expensive but easy arduino+GPS+SD Card stack, a nice custom board or (the option I'm leaning toward for now) AA simpler board that plugs into a phones earphone socket and offloads the hard work of logging, GPS, UI to the phone. I think this last idea would be best as it will keep costs very low and allow me to get started without waiting 2 months for a GPS breakout board. If I go with this option, I'll just need a fairly small PCB with a few IR LEDs and IR recievers (like those in DVD players, which have some extra circuitry built in to make life easy), a micro (probably an ATtiny85 just to be consistent) and a battery connector.
    The 'slaves' will be easier. Each one will be an ATtiny85, a boost converter to power from a AA battery, an IR LED/reciever pair, an electret microphone with a preamp (1 transistor, some resistors), an RGB LED for status info, a push button or two for input (may need a shift register if I go with two buttons and an RGB LED, but I'll try to get away with just the pins available) and a battery holder.
    Since the whole goal of this project is to keep everything small, cheap and robust, some professionally made PCBs will be a much better fit than my usual messy protoboard mashups, and if I ever plan on selling these having some nice purple prototypes would be useful ;)
  • ATtinys ready to go
    johnowhitaker04/26/2015 at 16:03 0 comments
    I have my tool-chain all set up. Tested it today by uploading the obligatory LED blinking program.
    The code will be written in C, compiled with gcc-avr and uploaded with a bus pirate (my favourite tool of late) using avrdude -p attiny85 -c buspirate -P /dev/ttyUSB0.
    Using the bus pirate as an AVR programmer is wonderful - no external components or power needed. I just connect +3.3V and GND to +V and GND on the 'tiny, wire up MOSI and MISO, CLK goes to SCK on the 'tiny and CS goes to RESET (pin 1 of the ATtiny85). Here is the makefile I use:
    DEVICE     = attiny85
    CLOCK      = 1000000
    PROGRAMMER = -c buspirate -P /dev/ttyUSB0
    OBJECTS    = main.o
    FUSES      = -U lfuse:w:0x62:m -U hfuse:w:0xdf:m -U efuse:w:0xff:m
    # generated by http://www.engbedded.com/fusecalc/
    AVRDUDE = avrdude $(PROGRAMMER) -p $(DEVICE)
    COMPILE = avr-gcc -Wall -Os -DF_CPU=$(CLOCK) -mmcu=$(DEVICE)
    all:	main.hex
    .c.o:
    	$(COMPILE) -c $< -o $@
    .S.o:
    	$(COMPILE) -x assembler-with-cpp -c $< -o $@
    .c.s:
    	$(COMPILE) -S $< -o $@
    flash:	all
    	$(AVRDUDE) -U flash:w:main.hex:i
    fuse:
    	$(AVRDUDE) $(FUSES)
    install: flash fuse
    load: all
    	bootloadHID main.hex
    clean:
    	rm -f main.hex main.elf $(OBJECTS)
    main.elf: $(OBJECTS)
    	$(COMPILE) -o main.elf $(OBJECTS)
    main.hex: main.elf
    	rm -f main.hex
    	avr-objcopy -j .text -j .data -O ihex main.elf main.hex
    disasm:	main.elf
    	avr-objdump -d main.elf
    cpp:
    	$(COMPILE) -E main.c
    Nice to have everything ready, so now I can get down to prototyping. I also plan on whipping up a PCB during my next Altium lecture (uni student, so free access) although I am tempted to go with Kicad. The only reason I'm considering Altium is that this project will probably be simple enough for others to reproduce just by looking at the schematic, and I need the practice...
View all 5 project logs
