Fitting the IR sensor
A project log for Internet Split Flap Weather Clock
Internet controlled weather station that shows the current weather with a split flap display.
sephendevosSephenDeVos 03/24/2015 at 08:580 Comments
You'll see the IR sensor blink when the display shows the sun symbol and the display stops briefly and then continues to rotate to a fixed position.
