Attraction
A project log for Internet Split Flap Weather Clock
Internet controlled weather station that shows the current weather with a split flap display.
sephendevosSephenDeVos 03/25/2015 at 07:200 Comments
Drilled eight 5mm holes by hand about 3mm deep in the case and the front panel. Then glued in some 5x3mm magnets that i bought from aliexpress. after that i primed and painted the case. I think the paint will scratch from the magnets. But a black marker will fix that.
