Matlab code considerations
The following considerations will be illustrated using a Matlab program which computes Conway's life. Parts of the code are explained below.
Examples
  1. Conway's life.
    The rule is:
    • Sum the 8 nearest neighbors
    • If the sum=2 then the state does not change
    • If the sum=3 then the state=1
    • Otherwise the state=0
    The code:
    x = 2:n-1;
    y = 2:n-1;
      %nearest neighbor sum
    sum(x,y) = cells(x,y-1) + cells(x,y+1) + ...
    		   cells(x-1, y) + cells(x+1,y) + ...
    		   cells(x-1,y-1) + cells(x-1,y+1) + ...
    		   cells(3:n,y-1) + cells(x+1,y+1);
    % The CA rule
    cells = (sum==3) | (sum==2 & cells);
  2. Surface Tension
    The rule is:
    • Sum the 8 nearest neighbors and the cell itself
    • If the sum< 4 or sum=5 then the state=0
    • Otherwise the state=1
    The code:
    x = 2:n-1;
    y = 2:n-1;
                cells(3:n,y-1) + cells(x+1,y+1)+...
                cells(x,y);
            % The CA rule
            cells = ~((sum< 4) | (sum==5));
  3. Percolation Cluster
    The rule:
    • Sum the 8 nearest neighbors of each cell (cells are binary valued, 0/1). Cells also have a separate state variable (called 'visited') which records if they have ever had a nonzero neighbor before.
    • Compute a random number r between 0 and 1.
    • If the sum> 0 (at least one neighbor) and the r>threshold, and the cell has never had a neighbor then cell=1.
    • If the sum> 0 set the "visited" flag for the cell to record that the cell has a nonzero neighbor.
    The update code:
    	sum(2:a-1,2:b-1) = cells(2:a-1,1:b-2) + cells(2:a-1,3:b) + ...
                            cells(1:a-2, 2:b-1) + cells(3:a,2:b-1) + ...
                            cells(1:a-2,1:b-2) + cells(1:a-2,3:b) + ...
                            cells(3:a,1:b-2) + cells(3:a,3:b);
        pick =  rand(a,b);
        cells = cells  | ((sum>=1) & (pick>=threshold) & (visit==0))  ;
        visit = (sum>=1) ;
    The variables a and b are the size of the image. The inital image is determined by graphics operations. The following statements set up axes of a fixed size, write text into the axes, then grab the contents of the axes and put them back into an array using the getframe function..
    ax = axes('units','pixels','position',[1 1 500 400],'color','k');
    text('units', 'pixels', 'position', [50,255,0],...
        'string','BioNB','color','w','fontname','helvetica','fontsize',100)
    text('units', 'pixels', 'position', [120,120,0],...
        'string','441','color','w','fontname','helvetica','fontsize',100)
    initial = getframe(gca);
    [a,b,c]=size(initial.cdata);
    z=zeros(a,b);
    cells = double(initial.cdata(:,:,1)==255);
    visit = z ;
    sum = z;
    After a few dozen time steps (starting with the BioNB 441 image) we get the following image. Click on it to see a full size image.
  4. Excitable media (BZ reaction or heart)
    The rule:
    • Cells can be in 10 different states. State 0 is resting. States 1-5 are active, and states 6-9 are refractory.
    • Count the 8 nearest neighbors of each cell which are in one of the active states.
    • If the sum is greater or equal to 3 (at least three active neighbors) then cell=1.
    • States 1 to 9 occur stepwise with no more input. If state=1 then the next state=2. If state=2 then the next state=3, and similarly of all the states up to 9. If state=9 then the next state=0 and the cell is back at rest.
    The update code:
    x = [2:n-1];
    y = [2:n-1];
        sum(x,y) = ((cells(x,y-1)> 0)&(cells(x,y-1)< t)) + ((cells(x,y+1)> 0)&(cells(x,y+1)< t)) + ...
            ((cells(x-1, y)> 0)&(cells(x-1, y)< t)) + ((cells(x+1,y)> 0)&(cells(x+1,y)< t)) + ...
            ((cells(x-1,y-1)> 0)&(cells(x-1,y-1)< t)) + ((cells(x-1,y+1)> 0)&(cells(x-1,y+1)< t)) + ...
            ((cells(x+1,y-1)> 0)&(cells(x+1,y-1)< t)) + ((cells(x+1,y+1)> 0)&(cells(x+1,y+1)< t));
        cells = ((cells==0) & (sum>=t1)) + ...
                2*(cells==1) + ...
                3*(cells==2) + ...
                4*(cells==3) + ...
                5*(cells==4) + ...
                6*(cells==5) +...
                7*(cells==6) +...
                8*(cells==7) +...
                9*(cells==8) +...
                0*(cells==9);
    An image from this CA after spiral waves develop is shown below.
  5. Forest Fire
    The rule:
    • Cells can be in 3 different states. State=0 is empty, state=1 is burning and state=2 is forest.
    • If one or more of the 4 neighbors if a cell is burning and it is forest (state=2) then the new state is burning (state=1).
    • There is a low probablity (say 0.000005) of a forest cell (state=2) starting to burn on its own (from lightning).
    • A cell which is burning (state=1) becomes empty (state=0).
    • There is a low probability (say, 0.01) of an empty cell becoming forest to simulate growth.
    • The array is considered to be toroidly connected, so that fire which burns to left side will start fires on the right. The top and bottom are similarly connected.
    The update code:
    	sum = (veg(1:n,[n 1:n-1])==1) + (veg(1:n,[2:n 1])==1) + ...
               (veg([n 1:n-1], 1:n)==1) + (veg([2:n 1],1:n)==1) ;
        veg = ...
             2*(veg==2) - ((veg==2) & (sum> 0 | (rand(n,n)< Plightning))) + ...
             2*((veg==0) & rand(n,n)< Pgrowth) ;
    Note that the toroidal connection is implemented by the ordering of subscripts.
  6. Gas dynamics
    This CA (and the next two) are used to compute motion of particles. This application requires a different kind of neighborhood. The neighborhood of a cell varys on each time step so that motion in a certain direction will continue in the same direction. In other words, the rule conserves momentum, which is the basis of dynamical calculations. The neighborhood used is called a Margolis neighborhood and consists of overlapping 2x2 blocks of cells. In the following diagram, the upper-left 4 cells are the neighborhood during an even time-step, the bottom-right 4 cells are the neighborhood during an odd time-step. A given cell has 3 neighbors at each time-step, but the specific cells which constitute the neighbors flips back and forth.
    even even
    even cell odd
    odd odd
    The rule:
    • This is called a HPP-GAS rule. See reference [1] Chapter 12..
    • Cells have 2 states. State=0 is empty, state=1 represents a particle in motion.
    • To make a particle collision (which conserves momentum and energy), treat the case of exactly two particles on a diagonal as if they hit and deflected each other 90 degrees. This is done by converting one diagonal to the other on the time-step. You can implement this by rotating the 4 cells counterclockwise by one cell.
    • To make a particle collide with a wall, simply leave its state unchanged. This causes a reflection.
    The update code:
    	p=mod(i,2); %margolis neighborhood, where i is the time step
        %upper left cell update
        xind = [1+p:2:nx-2+p];
        yind = [1+p:2:ny-2+p];
        %See if exactly one diagonal is ones
        %only (at most) one of the following can be true!
        diag1(xind,yind) = (sand(xind,yind)==1) & (sand(xind+1,yind+1)==1) & ...
            (sand(xind+1,yind)==0) & (sand(xind,yind+1)==0);
        diag2(xind,yind) = (sand(xind+1,yind)==1) & (sand(xind,yind+1)==1) & ...
            (sand(xind,yind)==0) & (sand(xind+1,yind+1)==0);
        %The diagonals both not occupied by two particles
        and12(xind,yind) = (diag1(xind,yind)==0) & (diag2(xind,yind)==0);
        %One diagonal is occupied by two particles
        or12(xind,yind)  = diag1(xind,yind) | diag2(xind,yind);
        %for every gas particle see if it near the boundary
        sums(xind,yind) = gnd(xind,yind) | gnd(xind+1,yind) | ...
                            gnd(xind,yind+1) | gnd(xind+1,yind+1) ;
        % cell layout:
        % x,y    x+1,y
        % x,y+1  x+1,y+1
        %If (no walls) and (diagonals are both not occupied)
        %then there is no collision, so move opposite cell to current cell
        %If (no walls) and (only one diagonal is occupied)
        %then there is a collision so move ccw cell to the current cell
        %If (a wall)
        %then don't change the cell (causes a reflection)
        sandNew(xind,yind) = ...
            (and12(xind,yind)  & ~sums(xind,yind) & sand(xind+1,yind+1)) + ...
            (or12(xind,yind) & ~sums(xind,yind) & sand(xind,yind+1)) + ...
            (sums(xind,yind) & sand(xind,yind));
        sandNew(xind+1,yind) = ...
            (and12(xind,yind)  & ~sums(xind,yind) & sand(xind,yind+1)) + ...
            (or12(xind,yind) & ~sums(xind,yind) & sand(xind,yind))+ ...
            (sums(xind,yind) & sand(xind+1,yind));
        sandNew(xind,yind+1) = ...
            (and12(xind,yind)  & ~sums(xind,yind) & sand(xind+1,yind)) + ...
            (or12(xind,yind) & ~sums(xind,yind) & sand(xind+1,yind+1))+ ...
            (sums(xind,yind) & sand(xind,yind+1));
         sandNew(xind+1,yind+1) = ...
            (and12(xind,yind)  & ~sums(xind,yind) & sand(xind,yind)) + ...
            (or12(xind,yind) & ~sums(xind,yind) & sand(xind+1,yind))+ ...
            (sums(xind,yind) & sand(xind+1,yind+1));
        sand = sandNew;
  7. Diffusion limited aggregation
    This system simulates sticky particles aggregating to form a fractal structure. particle motion takes place with a rule similar to the HPP-GAS rule in example 6. The difference is that particles are assumed to be bouncing around in some dense (but invisible) liquid. The effect is to randomize the direction of motion of every particle at every time step. Put differently, every time-step is a collision step. The simulation is also seeded with one fixed particle in the center of the array. Any diffusing particle which touches it sticks to it, and itself becomes a non-moving, sticky particle.
    The rule:
    • Use a Margolus neighborhood. At every time step, rotate the 4 cells either clockwise or counterclockwise by one cell with equal probability. The rotation randomizes the velocities.
    • After the move, if one or more of the eight nearest neighboors is a fixed, sticky particle, then freeze the particle and make it sticky.
    The update code:
        %random velocity choice
        vary = rand(nx,ny)< .5 ;
        vary1 = 1-vary;
        %diffusion rule -- margolus neighborhood
        %rotate the 4 cells to randomize velocity
            vary(xind,yind).*sand(xind+1,yind) + ... %cw
            vary1(xind,yind).*sand(xind,yind+1) ;    %ccw
            vary(xind,yind).*sand(xind+1,yind+1) + ...
            vary1(xind,yind).*sand(xind,yind) ;
            vary(xind,yind).*sand(xind,yind) + ...
            vary1(xind,yind).*sand(xind+1,yind+1) ;
            vary(xind,yind).*sand(xind,yind+1) + ...
            vary1(xind,yind).*sand(xind+1,yind) ;
        sand = sandNew;
        %for every sand grain see if it near the fixed, sticky cluster
        sum(2:nx-1,2:ny-1) = gnd(2:nx-1,1:ny-2) + gnd(2:nx-1,3:ny) + ...
                            gnd(1:nx-2, 2:ny-1) + gnd(3:nx,2:ny-1) + ...
                            gnd(1:nx-2,1:ny-2) + gnd(1:nx-2,3:ny) + ...
                            gnd(3:nx,1:ny-2) + gnd(3:nx,3:ny);
        %add to the cluster
        gnd = ((sum> 0) & (sand==1)) | gnd ;
        %and eliminate the moving particle
        sand(find(gnd==1)) = 0;
    The following image shows the fixed cluster after many time steps.
  8. Sand pile
    The cross-section of a pile of sand can be modeled using a Margolus neighborhood to propagate cells, but with a different motion rule
    The rule:
    • See reference [2] Chapter 2.2.6..
    • Cells have 2 states. State=0 is empty, state=1 represents agrain of sand.
    • On any step, a particle can fall toward the bottom of the the 2x2 block. The possible transitions are shown below. Walls and floors stop motion.
    • see Full doc link for the matrix state transitions
      The update code:
          sand(nx/2,ny/2) = 1; %add a grain at the top
          %randomize the flow -- 10% of the time
          vary = rand(nx,ny)< .9 ;
          vary1 = 1-vary;
              gnd(xind,yind).*sand(xind,yind) + ...
              (1-gnd(xind,yind)).*sand(xind,yind).*sand(xind,yind+1) .* ...
                  (sand(xind+1,yind+1)+(1-sand(xind+1,yind+1)).*sand(xind+1,yind));
              gnd(xind+1,yind).*sand(xind+1,yind) + ...
              (1-gnd(xind+1,yind)).*sand(xind+1,yind).*sand(xind+1,yind+1) .* ...
                  (sand(xind,yind+1)+(1-sand(xind,yind+1)).*sand(xind,yind));
              (1-sand(xind,yind+1)) .* ...
              (  sand(xind,yind).*(1-gnd(xind,yind)) + ...
                 (1-sand(xind,yind)).*sand(xind+1,yind).*(1-gnd(xind+1,yind)).*sand(xind+1,yind+1));
              (1-sand(xind+1,yind+1)) .* ...
              (  sand(xind+1,yind).*(1-gnd(xind+1,yind)) + ...
                 (1-sand(xind+1,yind)).*sand(xind,yind).*(1-gnd(xind,yind)).*sand(xind,yind+1));
          %scramble the sites to make it look better
          temp1 = sandNew(xind,yind+1).*vary(xind,yind+1) + ...
              sandNew(xind+1,yind+1).*vary1(xind,yind+1);
          temp2 = sandNew(xind+1,yind+1).*vary(xind,yind+1) + ...
              sandNew(xind,yind+1).*vary1(xind,yind+1);
          sandNew(xind,yind+1) = temp1;
          sandNew(xind+1,yind+1) = temp2;
          sand = sandNew;
References
[1] Cellular Automata Machines by Tommaso Toffoli and Norman Margolus, MIT Press, 1987.
[2] Cellular Automata Modeling of Physical Systems by Bastien Chopard and Michel Droz, Cambridge University Press, 1998.
