DIY Raspberry Pi MP3-player
A simple project to sharpen my python on and get a grip of all the headaches that come up when developing wearable electronics.
Since publication of the platform, the Raspberry Pi has been popular among students and hackers alike. It's small, cheap, versatile and open-source. The platform is not very powerful, but it never intended to be. Quite a few people have been eyeing the 'Pi for a possible candidate for wearable technology. Afterall, its powersource is a simple 5V micro-USB interface and can easily be powered for hours by a simple powerpack. So I figured: I need a project to get to grips with Python. I have 2 Raspberry Pi's and a soldering iron. I'm going to build a 'headless setup that plays mp3's over a headset.' What could go wrong? This project page describes all features and 'stuff that went wrong'. Although at this point I have a decent piece of software, stuff still needs to be done and I'll update accordingly.
Keyboard: Since I'm going to use this setup 'wearable', headless and thus without conventional interface I needed some way to control what was playing and at what level. To this end, I've soldered together a small circuitboad with 6 switches. The switches are wired to a common +3.3V and connected to GPIO pins on the Raspberry Pi. The resistors you see in the picture are pull-down resistors that make for a smooth transition between 0 and 1. To process the states for the given GPIO pins, I use the RPIO library (See also the links) This library allows the developer to utilise a callback mechanism, triggering functions that in turn execute commands. Maybe more on that when I put the code on GIT...
  • Got feedback on git!
    Daemon informatica • 03/27/2014 at 10:44 • 0 comments
    Wow! unexpected: People actually think my code is impressive enough to comment on! ^_^ Somebody that send feedback about the fact that the library is pretty well written but the default volume (60%) is too low for their taste. While I can't judge their setup from here, he raised an interesting point: The current default volume is hardcoded in the library. So today I took a moment to fix that: Moved the default volume to the settings file.
View project log
jody.fox wrote 02/17/2017 at 04:40 • point
Hey! I think your project is exactly what I'm looking for as my first big project.  I'd like to put a RPi inside an old radio I refinished.  I have an external USB HD with tons of old timey tunes.  If I understand correctly, looking at your main.py,  you set up your switches/GPIOs  and  pass they're state to a dependancy(?)  that plays the audio? Does the USB HD need to be "mounted"? thanks
