A project log for Shower water repurposer
The idea is to take the water used in a shower to use for flushing the toilet, there is no sense in using drinkable water for that
leandroleandro 08/07/2015 at 00:290 Comments
The code worked very well, so i decided to make it more complicated. I added a reserve tank to save more shower water if the toilet tank is full with an overfill-avoid-pipe. The new code works well also.
There's a new drawing to show the modifications. I am keeping the previous ones as references.
The scale model is halfway done, probably i'll finish it this weekend.
