pialarm_-_ponoko_2.svg
Laser cut file for the enclosure. I had ponoko.com do the cut using veneered MDF with a thickness of 5.7mm. Veneered MDF looks great after staining and a coat of polyurethane.
svg+xml - 597.68 kB - 03/30/2017 at 00:10
Download
pialarm_-_lens.svg
This is for the diffuser to fit into the window over the LCD. I used gray tinted acrylic 3mm thick.
svg+xml - 664.30 kB - 03/30/2017 at 00:10
Download
PiAlarm.fzz
Circuit diagram
fzz - 108.24 kB - 03/30/2017 at 00:09
Download
