13D Print the brackets
They took around 2-hours each for me. I have a Lulzbot mini, using the fastest mode in Cura. I printed in PLA.
2Insert brass screw inserts
There are four holes in the model. Use which ever two match up with the holes in the drawer runner (You actually only need one - all the screws do is stop the runners from coming out when you pull the draw)
3Hammer in the shelf supports
They should hammer in quite easily. I put the rounded side down on both.
4Trim down the shelf
You will need to make the shelf 80mm thinner to accomodate the runners and brackets
5Cutout holes for the bins
I should have used a jigsaw, but I couldn't find mine. I used a multi-tool which made it look like it was cutout by a drunk Monkey. Thankfully the bins have a lip which hides the rough cut.
6Screw the runners to the shelf
I lined to top of the runner up to the top of the shelf, so it sits flush. A couple of self tapping screws will hold it in.
7Insert the runners and screw in the screws
I found I had to push the brackets in to their holding holes, then slide the runners in to the brackets, and put the screws in in-situ.
