This is an idea to store the automobile exhaust gases instead of letting it out into the atmosphere
Really cool that you got the money and expert help to get it done. Not many people get that opportunity. All the best for the project.
One piece of advice: Make sure it works on paper before starting on a prototype. Use some estimates to work out all the details of the design. The devil is in the details! That is the whole point of engineering. Its one thing to have an idea but a whole different thing to make it work. I have experienced it first hand. Many people have brilliant ideas but only some of them actually get implemented. So many huge scientific projects run into problems because of engineering challenges (for example, fusion reactors).
Have you documented your progress anywhere? If not, you should because it is very beneficial to you and others. Its really easy to start a blog now and document everything. Take a look at this article:
Hi Bis. I guess we both came up with the idea independently at different points in time. It happens. Anyway, I did not go ahead with the project after realizing that it has many practical constraints which either limit its efficiency or would be prohibitively expensive. So, I did not build any prototypes.
First thing is the compressor which would need a lot of energy to fit the gases within a reasonably sized tank/container. The second is the size of the container which cannot be too big. Thirdly, the disposal of those collected gases. How were you able to solve these problems?
I am planning to use sucction pumps or fans to suck in the exhaust and make it directly get adsorbed over a bed of activated charcoal.
Actually we have to put up a workshop in December at a science museum. Our entire workshop is funded by US museum grant. So, we h ave got lots of experts to help us, both from India and from US.
I ( a student of grade XII) along with my team am planning to make a prototype of this (after considerable changes) and put it up in the workshop......
I am working on this project for another project called "HAcking SPace Project".
www.hackingspacestudentexchange.com
check our website for more details.
Also remember that you are not just dealing with the volume of the gases created in combustion, you are also dealing with the volume of air inhaled by the engine to burn the fuel with in the first place.
Another thing to remember is that exhaust systems are carefully designed and crafted to increase engine efficiency, sometimes by significant amounts. Will this system harm the efficiency of the engine it is being used on?
I'd love to see a prototype of this in use on an actual internal-combustion engine.
Oh, and judging from your sketch, you'd need a compressor roughly the same size as the engine it is being used on... Think about that for a moment.
I encourage you to do some rough calculation on the volume of gas you'll need to compress. How many liters of exhaust are produced by a liter of fuel? How much pressure will the compressed exhaust be under? How much energy is required to compress this volume of gas to this pressure?
Any energy used to compress the gas will require more fuel to be consumed. I fear you'll end up using more energy in compressing the exhaust than will be used to power the vehicle.
The total energy used by a vehicle which compresses its exhaust gas will be much more than a conventional vehicle. This increase in energy use will likely cause more environmental problems than compressing the gas solves.
great idea heres a little background info. A cars exhaust is 98% carbon dioxide after the cat. Which I think would be great to store. After all CO2 is used as a welding gas and in fountain drinks. The gases going in are HC(gas) and O2. After complete combustion HC and O2 will turn in to CO2 and H2O(mostly). partially burnt fuel will turn into CO carbon monoxide so a catalytic converter is a must to keep CO levels low. Also an engine is a pump. Think air compressor. A 1 piston compressor can fill a 50 gallon tank in 20minutes. Multiple cylinders plus expanding gases = really large storage tank or some sort of pressure relief
jan.ostman
sean d'epagnier
