The custom LCD connector
A project log for Portable environmental monitor
A handheld, battery powered, sensor array unit for environmental monitoring focused mostly on air quality using a global infrastructure.
radu-motisanRadu Motisan 08/31/2015 at 15:403 Comments
The Beta variants used a custom LCD connector. Initially built in two iterations, the first relied on the XPT2046 touchscreen driver which was eventually discarded due to unforeseen problems presented previously. The second connector was used in the Beta units:
The oversized FPC connector also required a large area to be milled out in the enclosure, to allow assembling. It really had to be replaced by a standard connector. The present iteration puts this new change in place. Finally the connectors have arrived, even before the PCBs:
The new FPCs have been custom designed and manufactured, since they required specific parameters such as 0.8mm pitch and 18pins, to fit the ILI9341 connector. And they do. Perfectly, as the pictures show
Radu Motisan wrote 02/27/2016 at 11:41 point
This was custom designed and manufactured.
Adam wrote 12/09/2017 at 19:38 point
Can you share the details on how you go about doing this? I've got a project where I need to connect about a hundred of these ILI9341 displays, and having connectors like this would make my life about a million times easier, but I don't know where to start about getting them custom-made.
Volki wrote 02/27/2016 at 06:09 point
Where can I buy this 0.8mm pitch fpc socket?
I can't find it anywhere. (Ebay, aliexpress,...)
