Testing parts
A project log for The Vision Project
A project to provide a form of "vision" to the blind and partially sighted.
haydn-joneshaydn jones 04/17/2015 at 16:280 Comments
HC-SR04
trig pin 8
echo pin 9
5v
servo pin 2
#include <Servo.h>
Servo myservo;  // create servo object to control a servo
int ang;    // angleofservo
const int TriggerPin = 8; //Trig pin
const int EchoPin = 9; //Echo pin
long Duration = 0;
void setup(){
myservo.attach(2);  // attaches the servo on pin 2 to the servo object
pinMode(TriggerPin,OUTPUT); // Trigger is an output pin
pinMode(EchoPin,INPUT); // Echo is an input pin
Serial.begin(9600); // Serial Output
void loop(){
digitalWrite(TriggerPin, LOW);
delayMicroseconds(2);
digitalWrite(TriggerPin, HIGH); // Trigger pin to HIGH
delayMicroseconds(10); // 10us high
digitalWrite(TriggerPin, LOW); // Trigger pin to HIGH
Duration = pulseIn(EchoPin,HIGH); // Waits for the echo pin to get high
// returns the Duration in microseconds
long Distance_cm = Distance(Duration); // Use function to calculate the distance
Serial.print("Distance = "); // Output to serial
Serial.print(Distance_cm);
Serial.println(" cm");
ang = map(Distance_cm, 0, 1023, 0, 179);
myservo.write(ang);
delay(100); // 10 readings per second
long Distance(long time)
// Calculates the Distance in cm
// ((time)*(Speed of sound))/ toward and backward of object)
long DistanceCalc; // Calculation variable
DistanceCalc = ((time /29) / 2); // Actual calculation in cm
//DistanceCalc = time / 74 / 2; // Actual calculation in inches
return DistanceCalc; // return calculated value
Just tested the servos with sensors as a proof of concept. Will need to work on smoothing and fine tuning the angles,possibly with gearing/levers.
