The plan here is to build up intuition for HiD representations in parallel coordinates:
Examples
References
(1) Calibrate you eyes to recognize high-dimensional objects from their projections. Diane Cook and Peter Sutherland. http://www.public.iastate.edu/~dicook/JSS/paper/paper.html
(2) Visualisation of High Dimensional Data. Dr. Carolina Cruz-Neira and Laura Arns
http://www.vrac.iastate.edu/research/visualization/multivariate/
(3) Polytope visualization. Gordon Kindelmann.
http://www.graphics.cornell.edu/~gordon/peek/
(4) N-Land: a Graphical Tool for Exploring N-Dimensional Data. Matthew O. Ward Jeffrey T. LeBlanc and Rajeev Tipnis.
http://davis.wpi.edu/~matt/courses/nland/cgi93.html
(5) Don't panic ... just do it in parallel! Al Inselberg, COMPUTATION STAT 14: (1) 53-77 1999
(6) Visual data mining with parallel coordinates Al Inselberg, COMPUTATION STAT 13: (1) 47-63 1998
(7) MULTIDIMENSIONAL LINES .1. REPRESENTATION. INSELBERG A, DIMSDALE B, SIAM J APPL MATH 54: (2) 559-577 APR 1994
(8) MULTIDIMENSIONAL LINES .2. PROXIMITY AND APPLICATIONS. INSELBERG A, DIMSDALE B, SIAM J APPL MATH 54: (2) 578-596 APR 1994
(9) HYPERDIMENSIONAL DATA-ANALYSIS USING PARALLEL COORDINATES. WEGMAN EJ. J AM STAT ASSOC 85 (411): 664-675 SEP 1990
(10) THE ANALYSIS OF T48 LOW PRESSURE TURBINE INLET TEMPERATURES USING PARALLEL COORDINATES. Frank S. Budny.
http://www.che.ufl.edu/visualize/THESIS/thesis.html
(11) Visualizing the Behavior of Higher Dimensional Dynamical Systems. R. Wegenkittl, H. L�ffelmann, and E. Gr�ller.
http://www.cg.tuwien.ac.at/research/vis/dynsys/ndim/
(12) Hierarchical Parallel Coordinates. Ying-Huey Fua.
http://davis.wpi.edu/~yingfua/cs563_1/hiervis.html
(13) High Dimensional Clustering Using Parallel Coordinates and the Grand Tour. Edward J. Wegman and Qiang Luo.
http://www.galaxy.gmu.edu/papers/inter96.html
