Minor update, I finally designed some proper 60 degree brackets for mounting to the side of the Kossel Pro. This way, things are not punched directly into the tower on the opposite side. It also gives more room so that the fist doesn't get in the way of the end effector. Files are on Thingiverse. Heres pictures.
Tyler Anderson
