Hackaday.io Hackaday.io
Sign up Log in
arduino based MPC like midi controller
bochenbochen
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3.4k views
7 comments
107 followers
  • Description
  • Details
  • Files 0
  • Components 3
    • View all
  • Logs 3
    • View all
  • Instructions 0
  • Discussion 7
View Gallery
3.4k
7
107
14
Team (1)
  • bochenbochen
Join this project's team
  • hearless midi to serial
  • source code
  • android app
completed project
MISC
arduino midi mpc
This project was created on 03/31/2015 and last updated 11 years ago.
Description
I didn't want to spend 100$ on AKAI MPD. I thought I can make one myself. So i bought a bunch of buttons, two 74151 multiplexers, an Arduino Uno and went to work. The program is very simple. It scans through all buttons (two buttons at time thanks to two multiplexeres), debounces buttons if needed and sends midi command through serial port (source code in links). On the other side of serial is PC with Hearless Serial to Midi software. This magnificent program converts serial input into midi commands. Then it can be used in all sorts of programs like FL Studio or ableton. If I ever make second version of it I will 1. use better (connected with each other) cables 2. use shift registers to read all buttons state at once. 3. use better (more silent) buttons Still it works like a charm and I'm left with 100$ in my pocket :)
Components
  • 1 × arduino uno
  • 2 × 74151 multiplexers
  • 16 × pushbuttons
Project Logs
Collapse
  • I've made an app for that
    bochen • 12/05/2015 at 18:58 • 0 comments
    I've made Android app that let's me play without a hassle of connecting to pc.
    Here is a link to it: (ITS FREEEEEE):
    https://play.google.com/store/apps/details?id=pl.orendi.bit.
  • midi-to-usb cable
    bochen • 11/01/2015 at 08:37 • 0 comments
    I've bought this little midi - to - ubs cable so I will not have to do the serial-to-usb software mumbo-jumbo every time.
    The istructions I will follow are here: http://shiftmore.blogspot.co.uk/2010/01/quick-and-dirty-arduino-midi-over-usb.html
  • video added
    bochen • 04/16/2015 at 18:28 • 0 comments
    Video with working stuff added:
View all 3 project logs
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Arturo wrote 06/09/2015 at 08:16 • point
you have the wiring diagram? your project is amazing!
bochen wrote 06/09/2015 at 08:34 • point
Hey, I don't have a diagram. I based on this: http://www.codetinkerhack.com/2012/11/how-to-turn-piano-toy-into-midi.html?m=1#more but this uses shift registers and I've used multiplexers but the idea is similar.
Hanging pin on multiplexer is always 1 (if you use TTL multiplexer at least like 74151). I used this idea and connected buttons to ground and the other side of the buttons to multiplexer IN pins. so when button is pressed multiplexer reads 0. So the logic is turned around there.
Than it is normal multiplexer scanning (going through all the addresses of multiplexer and reading all the inputs on the OUT pin of multiplexer).
hope that helps.
br
Pawel
Arturo wrote 06/09/2015 at 08:06 • point
Thanks!
Arturo wrote 06/09/2015 at 07:45 • point
you have sketch? please!
[deleted]
bochen wrote 06/09/2015 at 07:48 • point
Hey, yes it's here: https://gist.github.com/pbochenski/6a77521e7cebe0baaa9f
davedarko wrote 03/31/2015 at 21:37 • point
it's settled. I'll order some of those buttons! Any demo videos?
bochen wrote 04/01/2015 at 06:02 • point
yes do it. It's super easy and fun. I don't have any videos now but I can make one.
br!
An easy to build, simple to use stomp box for musicians using computerized effects for their electric/electronic instruments.
Project Owner Contributor
MIDI Stomp Box
thenetimptheNetImp
Minimalistic and easy to build USB MIDI controller, inspired by the AKAI EWI, the CASIO DH-200 and my own MiniWI.
TeensieWI woodwind USB MIDI controller
johan-berglundJohan Berglund
After two commercial USB MIDI adapters failed to work properly, I used an Arduino to successfully make my own.
Roland EP-77 USB MIDI Adapter
ronaldronald
My goal is to make a MIDI-controller that you can use to make music with.
DIY MIDI FIGHTER
mathias-sundgrenMathias Sundgren
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "arduino based MPC like midi controller", please tell us the reason.
Send message
Remove Member
