The Smart Garden
An Arduino IoT Farming Experiment
Growing food is expensive. Farm grown food requires a lot of labor. Greenhouse production requires a lot of energy. My project, "The Smart Garden" will attempt to produce food for less.
I will deploy a concept into The Smart Garden called "Root Zone Optimization". I think of the root zone as the engine of the plant. I believe that subjecting it to a climate controlled zone should be proportionally more important in terms of plant yield, relative to energy usage. I liken this concept to a radiator system maintaining optimal operating temperature in the engine of a car. The Smart Garden will also be fully automated, log multiple sources of data, communicate with the cloud, and capable of wireless control. As I contribute to this project, I will first show the construction of The Smart Garden, and then I will report its results. The goal of this project is to prove that Root Zone Optimization coupled with automation can lead to a new, lower cost version of food produ
The Smart Garden is being built to serve as a platform for future robotic farming systems. I believe that there is fundamental shortcoming in the Urban Farming movement, which is getting individuals to once again grow their own food. My idea with The Smart Garden is to include as many components, sensors, and robotics as possible in order to obtain the data necessary to start building a more efficient agricultural infrastructure from networked IoT data.
Existing and planned components of the Smart Garden are listed below:
  • Smart Garden Casing
    • Raised bed system with the root zone housing enclosed in sheet metal, plywood, plastic wrap, and steel mesh. All raw materials were cut and mounted in segments so as to allow future access to specific areas of the garden.
    • The goal was to reduce heat loss as much as possible order to get optimal data on Root Zone Optimization's impact.
    • The plant accesses the atmosphere via a hinged greenhouse plastic roofing. The roofing has a hole for the plant's root stem.
  • Smart Garden Irrigation and Feeding
    • Three separate 5 gallon marine fuel tanks rest below the plant root zone. This is done to heat and cool the water supply in conjunction with the root zone.
    • Water is pumped directly to the plant based on inputs from a water level sensor in the plant root zone.
    • Liquid nutrients are pumped into each 5 gallon tank and are triggered via flow meters.
    • A rain collection system dissipates a majority of the rain that falls on the surface area of the roofing system to a water reserve tank. The water reserve tank provides water to each marine tank and is connected via an inflow and overflow tubing system.
    • The water reserve tank will serve as an Aquaponics system.
    • Of the three planters in the Smart Garden, the outside two will grow tomatoes. The middle plant will grow basil. An Aeroponics system will be employed into this plant.
  • Smart Garden Electrical
    • The Smart Garden will be controlled by an Arduino Mega.
    • Circuitry will first be hand soldered, then a shield will be printed, then a custom circuit board will be made.
    • Relays will be used for future usability in higher power systems.
    • A 12V wall wart will power The Smart Garden, Then a solar panel with battery charging station.
  • Smart Garden IoT
    • Smart Garden will log data via SD card.
    • Wifi, Bluetooth, and possibly cellular will ultimately be utilized to log data, view real time data, and control the smart garden. Plotly, Carriots, and other third party cloud services will be tested.
    • Design for a mobile app will commence within Android Studio, but testing of the many IoT development platforms will take place. Push notifications will be a large aspect of the development.
    • Additional sensors such as photo resistors, humidity sensors, ph sensors...etc will be incorporated to enhance the data pool.
  • Smart Garden Plant Support System
    • A CNC based vertical caging system triggered by weight on sensors of each section of the system. When the weight on a segment of the caging system reaches the optimal amount, a CNC controlled robotic arm will raise and attach one end of the support wire to an elevated hook. This will have the impact of supporting a specific amount of plant for fruiting as well as closing off this section of the plant from incoming growth.
  • Just purchased the Intel RealSense SDK. Oh yea!!!!
The goal of The Smart Garden is simple...reduce the cost of food.
  • Smart Garden Mini
    Frank Vigilante05/13/2015 at 09:44 0 comments
    If The Smart Garden is the platform for an IoT gardening system parent, then it needs some children to receive its knowledge. Below is the Smart Garden Mini. I will create a new project to track the Mini so as to avoid confusion.
    - Explanation of its functions will also be provided at the new project page:
    https://hackaday.io/project/5999-the-smart-garden-mini
  • An overly expensive and redundant PCB
    Frank Vigilante04/24/2015 at 22:27 0 comments
    Because The Smart Garden is being built as a platform for future robotic gardening systems, I am going to throw cost minimization out the window for the first PCB. It will include many components that serve a redundant purpose. From this platform, I will then be able to reduce the PCB down to a more efficient design. So where do I even begin? In order to answer this question, I decided to gather a good portion of the electronics, and begin to map out my plan for the first board.
    This log will discuss which components shown above will be incorporated into the first PCB, and why....
    1. Power supply - The first PCB will take in 12V. It will likely have both, a barrel jack. and terminals so I can alternate between power adapters and solar panel supply (notice the solar charge controller and 12V adapters in the picture).
    2. Power Regulation - The PCB will regulate down to 5V and 3.3V. In the picture, you can see a 7805 creating a 5V supply in the breadboard in the middle bottom of the motherboard. The broadboard in the middle top has a 3.3V regulator (but i previously harvested the capacitors). For both of these, I will use really nice heat sinks and capacitors.
    3. Relays - I am going to keep using relays because I want to preserve the ability to not only shrink the smart garden design, but also scale it up big! The first PCB will probably have a bank of 14-16 relays.
    4. Micro-controller - I see no reason not to put a ATmega2560 in the first PCB. It should be able to handle everything that I want to do.
    5. Communication - This is where I am going to get really redundant with the first PCB. In the picture you can see a CC3000, a HC-04 BT module, a ESP8266-12x2, and a RF transmitter/receiver. The first PCB will likely include a CC3000, a ESP8266, and a Nordic semi conductor BT chip, but I am still all over the place on this one. Finally, you can see in the top right of the picture that I have a great wifi antenna ready to be deployed in the garden.
    Other Considerations:
    - The picture shows some maker slide, and some conductive rubber cord (https://www.adafruit.com/products/519).....this is a hint at my plans for the CNC plant support system.
    - A current sensing module is shown in the picture. The represents the inclusion of a component into the PCB that will measure and log energy usage.
    - An SD card is shown. This is to back up and preserve all data logged while testing various wireless communication modules.
    - I threw some photo resistors and a PIR motion sensor into the picture. The represents how the PCB will have auxiliary ports for adding and removing new sensors.
    - I threw my DSlogic (http://store.hackaday.com/products/dslogic) into the picture. This represents all the testing that will need to be done!
  • Max Power Consumption
    Frank Vigilante04/24/2015 at 04:22 0 comments
    Here is a nice little accounting of where the maximum power requirements of The Smart Garden stand:
  • Smart Garden Cooling System
    Frank Vigilante04/21/2015 at 02:35 0 comments
    I started contemplating how to cool The Smart Garden today. This Cooler Master liquid CPU cooler (the fan in the middle and radiator on the right) worked right out of the box using an Arduino Motor Shield. This is the front runner for the cooling system at this point.
  • Green Power
    Frank Vigilante04/17/2015 at 14:34 0 comments
    The Smart Garden would not be complete without some form of Green Energy...this solar panel will power it eventually.
  • Pumping Station Two
    Frank Vigilante04/17/2015 at 02:03 2 comments
    When growing tomatoes, the chemical balance of the root zone is very important. Too much nitrogen will hurt yield, too little phosphorus will hurt yield...etc. Liquid fertilizers are sold based on different combinations of nitrogen, phosphate, and potassium. The Smart Garden will be able to deliver specific amounts of nutrients to each plant using the pumps shown below:
    The items that are taped on to the pump terminals are flow meters, which will be discussed in detail later.
    As noted before, the pumps were found on Adafruit:
    https://www.adafruit.com/product/1150
    The flow sensors were also found on Adafruit:
    https://www.adafruit.com/products/828
  • Breaking Geographic Barriers With Data
    Frank Vigilante04/15/2015 at 05:00 0 comments
    Just by looking at the map of worldwide tomato production shown below, it is apparent that transportation costs represent a big factor in providing fresh tomatoes to certain regions of the world.
    The beauty of the IoT revolution is that we can now monitor and analyze the the different variables that cause this apparent fragmentation of the density of produce production. The first Smart Garden is programmed based on my research regarding optimal tomato growth, however, all data will be logged for implementation into future efficiency gains. Just imagine a world where a tomato plant in Illinois is warned about a cold snap coming from Minnesota...or buying a Smart Garden from the store, and using your mobile phone to program it to the optimal setting based on the atmospheric conditions of your location. The possibilities are endless! Implementation of an IoT framework is of the utmost importance for this project.
  • Efficient Space Utilization
    Frank Vigilante04/14/2015 at 20:52 0 comments
    When contemplating the utilization of space of my robotic garden, I thought back to my favorite story highlighting wealth creation abilities of my favorite business leader in history:
    While seeking a way to improve the efficiency of the exterior floor plans of the restaurants he operated, this man decided that the heating and air conditioning systems on the side of the building were an inefficient use of space. He called up his HVAC company, and told them that he wanted them to install the machines on the rooftop of his restaurants...they thought his idea was crazy, but ended up fulfilling his odd request. To this day, despite the ample space on the side of most buildings, suburban and rural commercial buildings have these machines on the roof.
    The Smart Garden's place in the farming landscape is to provide a backyard appliance for the suburban residential setting, and more importantly, to enhance the viability of the green roof by providing not just energy efficiency to the large building, but also a profitable food byproduct. In this way, the Smart Garden pays homage to this great businessman.
  • Smart Garden Tarp is Off!
    Frank Vigilante04/14/2015 at 18:48 0 comments
    With the tarp off, The Smart Garden is starting to show its form! As previously stated, this project is aiming to mimic the science of a car engine. For any mechanics out there, think of the Smart Garden components like this:
    Root System = Car Engine (In this case, I am working with a straight line 3 cylinder)
    Arduino Board = Powertrain Control Module
    8-Channel Relay = Power Distribution Center
    Water Level Sensor = Fuel System Sensors
    Temperature Sensor = Radiator Thermometer
    Heat Cables and Fan = Radiator System
    You can also see how I am taping up the wiring similar to the wiring in a car engine (I still need to drill the temp sensor and water pump into the planter):
  • Water Consumption - The Plant Knows Best
    Frank Vigilante04/10/2015 at 01:08 0 comments
    Providing the correct amount of water and nutrients to the plant is crucial. Too much water and the plant dies, too little water and the plant dies. For that reason, I will let the plant decide. I placed a liquid level sensor in the planter. When the water level gets low the sensor will tell the Arduino to turn on the water pump. This sensor was found on Adafruit.
    https://www.adafruit.com/product/464
View all 17 project logs
AVR wrote 05/08/2015 at 00:12 point
Hi I saw you project in the list of winners for the LightBlue Bean! Looking great! I'm also building an intelligent garden controller for my entry, I'm going more of a custom hardware route but yours looks like its coming along very nicely, I look forward to how your turns out, good luck!!
Frank Vigilante wrote 05/13/2015 at 09:38 point
Adam,
Your project looks awesome. The more robotic farming projects the better!
hydroMazing wrote 05/06/2015 at 19:45 point
Most impressive!
Frank Vigilante wrote 05/07/2015 at 04:11 point
Thank You!
