Smart Garden Tarp is Off!
A project log for The Smart Garden
An Arduino IoT Farming Experiment
frank-vigilanteFrank Vigilante • 04/14/2015 at 18:48•0 Comments
With the tarp off, The Smart Garden is starting to show its form! As previously stated, this project is aiming to mimic the science of a car engine. For any mechanics out there, think of the Smart Garden components like this:
Root System = Car Engine (In this case, I am working with a straight line 3 cylinder)
Arduino Board = Powertrain Control Module
8-Channel Relay = Power Distribution Center
Water Level Sensor = Fuel System Sensors
Temperature Sensor = Radiator Thermometer
Heat Cables and Fan = Radiator System
You can also see how I am taping up the wiring similar to the wiring in a car engine (I still need to drill the temp sensor and water pump into the planter):
