gerber1.zipNecessary files for odering PCBsZip Archive - 194.91 kB - 01/21/2018 at 22:11 |
flypi.img.torrentHere is a torrent file which should make it easier to download the prepared image for the flypix-bittorrent - 148.56 kB - 09/28/2017 at 05:30 |
FlyPi_v29.scadScad file containing all parts that need to be 3D printedx-openscad - 46.73 kB - 10/05/2016 at 22:07 |
electronics_draft.pdfDiagram of PCB layoutx-download - 16.33 kB - 10/04/2016 at 20:55 |
BOM.pdfBill of materials pdf 04.10.2016x-download - 48.20 kB - 10/04/2016 at 18:30 |
BOM.odsBill of materials ods 04.10.2016spreadsheet - 23.42 kB - 10/04/2016 at 18:30 |
BOM.xlsxBill of materials xlsx 04.10.2016sheet - 11.37 kB - 10/04/2016 at 18:30 |
156907-da-01-en-SPG_REGL_TS2596CM550_RN_TSC_TO263.pdfDatasheet for TS2596 switching voltage regulatoroctet-stream - 323.49 kB - 01/24/2016 at 21:27 |
956datasheet.pdfDatasheet for the 8X8 Blue led matrix from AdafruitAdobe Portable Document Format - 360.74 kB - 01/14/2016 at 16:44 |
STM.pdfDatasheet for TDA8139 voltage regulatorAdobe Portable Document Format - 84.01 kB - 01/14/2016 at 14:43 |
CD00000240.pdfDatasheet for L298N H-BridgeAdobe Portable Document Format - 599.36 kB - 01/14/2016 at 14:36 |
AD22100.pdfDatasheet for AD22100 temp sensorAdobe Portable Document Format - 183.50 kB - 01/14/2016 at 14:34 |
