Arduino, Raspberry Pi or beagleboard ?
A project log for Smart Dew-Point Water Harvester
Harvesting clean drinking water from sunshine.
robert-hartRobert Hart 05/21/2015 at 07:280 Comments
Now trying to decide on an appropriate controller platform which would need to be low powered so naturally I thought a Arduino. However I will want to test it in the field remotely over a G4 connection so the setting can be tweaked. The unit would monitor and log temperature and barometric pressure. Where a sustained drop in temperature and/or barometric pumps, fan etc. can be controlled for the best results.
