August 15th 2015 - Improved liquid cooling
A project log for Smart Dew-Point Water Harvester
Harvesting clean drinking water from sunshine.
robert-hartRobert Hart 08/14/2015 at 23:000 Comments
If you're trying to suck heat from a liquid it has to go somewhere and on this planet it's into the air. I've now added server fans and position spacing to ensure maximum airflow through the heat sink. I now have a dry cell temperature of -23C in each peltier.
