OpenBraille Steam
Using a low cost braille printer using the open source project
Making a low-cost Braille printer using the existing open source braille project. We are making this project to make it cheaper and more accessible to visually disabled people.This project is inspired by an open source project named OpenBraille which is made by Carlos Campos.(http://www.instructables.com/id/OpenBraille-a-DIY-Braille-Embosser/)
  • 1 × http://www.instructables.com/id/OpenBraille-a-DIY-Braille-Embosser/ All the components are listed in the above link.
  • Assemblying the components to form the printer
    akashupase02/13/2018 at 12:32 0 comments
    We followed the instructions that were provided in the Instructable OpenBraille project and fixed the different components.
    The required parts were drilled into the wooden frame and other components were fit as well to make the entire structure.
  • Filing of the 3D components
    akashupase02/13/2018 at 12:24 0 comments
    Since the 3D printed components were not precise and their supports were protruding out, we had to file them the extra part to make them precise.
  • Modifications made in the wheel attached to the pin head
    akashupase02/13/2018 at 12:20 0 comments
    We made modifications in the wheel that is attached to the pin head encoder. The 3d printed wheel had some gap between them due to which there were levelling issues. Due to this problem the wheel had stability issues and was toppling.
    We attached some padding (Double Sided Tape)
    on both the surfaces of the wheel in order to give it some stability.
  • Fabricating Pin head encoder
    akashupase02/12/2018 at 13:53 0 comments
    We fabricated the pin head encoder of the braille printer. The part was 3-d printed and also the nails were made according to the design provided in the Instructable project guideline
  • Laser printing the body of the project
    akashupase02/12/2018 at 13:41 0 comments
    We laser printed the body of Open braille using a 10mm wooden plywood. We made the design on Autodesk Fusion 360 using the dimension provided in the Instructable project.
View all 5 project logs
  • 1
    Step 1: Getting the Parts
    OpenBraille uses widely available parts on the market. Most of the components are originally used for 3D printers. The brain of the embosser is an arduino mega with a RAMPS board. The following parts are needed for the build:
    Arduino Mega 2560
    RAMPS board
    Stepper Drivers
    End Stops
    Servo Motor
    Steppers
    Rods
    Lead Screw Rods
    Power supply
    Coupler
    Bearing
    Screws
    Printer carriage
    10mm wood
  • 2
    Step 2: Printing the Parts
    All the parts can be 3D printed. Follow the link and get the files:
    https://www.thingiverse.com/thing:258673
  • 3
    Step 3: Building the Frame
    We used a 10mm Medium Density Fiber Board(MDF) for the frame. It was laser printed according to the dimensions provided in the picture attached.
View all 9 instructions
