So I spent six hours working on this with the viewers from the subreddit /r/WatchPeopleCode.
I got to the stage where the GUI that I'm building to test out some OpenCV features will compile, but the functionality isn't working. Plans for the next stream will be to get the ability to select camera sources dynamically as well as fixing the file path loading for the haarcascade files. Browse the current code as of this post can be browsed here:
https://github.com/benhoff/opencv/tree/76693717598c0eaaed1da0c7d38d9d5470ac4b77
Dependicies include Qt 5.4 and OpenCV 3.0 Beta.
I'm looking for collaborators! Pull requests are welcome on github, you can find me on Reddit as /u/beohoff or here.
The stream is located here:
