Reliability and future usage
A project log for Wifi controlled light switch
So far I use a servo with an ESP8266 to control the lightswitch
mlteM@lte 12/22/2015 at 16:120 Comments
After running for over half a year now, the voltage regulator got a bit exhausted and I had to add a big capacitor to buffer the current. There was also a bug in the code (string concatenation do not work well for bigger strings in node mcu), which caused it to reboot after some time, but this is also fixed now. Besides that, it is very stable and has low maintenance requirements. Also it is now part of my home automation project https://hackaday.io/project/8791-home-automation
