Mechanical bits!
A project log for Reflecting the sun into your home
My home doesn't face the sun, so it's dark and cool inside. I want to use mirrors to reflect sunlight into my home.
mimemime 10/05/2020 at 12:540 Comments
well, I ran out of time but I managed to hack something together.
The video is uploading now..
So I created a simple frame, and I added the motors to the frame.. Not in the way I intended!!!!! ;)
In order to finish it, I quickly tacked on the limit switches. You can go a few logs back to see how it is meant to look.
But roughly speaking, this is how I wanted to construct the frame.
List of components:
wood
screws
aluminium strips
mirror
The other components are already listed on the electronics bit.
