More de-coupling
A project log for Numitron Clock
MQTT-enabled Numitron clock with Arduino and ESP8266
harri-ohra-ahoHarri Ohra-aho 09/25/2015 at 16:000 Comments
As everything was connected up and the power was switched on there was a faint whine coming from somewhere in the circuit. I figured the Numitrons were causing some power fluctuations so I added a 100uF capacitor on the power rail. The whining stopped.
The power supply module I have already has capacitors but they didn't seem to help here.
