Missing Pins And Eagle Footprints
A project log for Gummi Worm Clock
I forgot to build something for the Bay Area Maker Faire Bring A Hack event. I started this on April 7th. The Faire is May 16th.
benchoffBenchoff 04/20/2015 at 16:000 Comments
I recieved my order from Adafruit this weekend. Checking out the pins for the RGB seven-segment displays, there are a few slight differences.
Yes, missing pins! There's no problem; the missing pins aren't connected to anything. They do, however, allow for a bit more flexibility in routing a project that uses these displays.
Other than that, these displays match my Eagle footprint, so I'm going to call that a win. Now I'm only waiting for the OSHPark boards to arrive, and I can start assembly.
