DS3231 RTC Up And Running
A project log for Gummi Worm Clock
I forgot to build something for the Bay Area Maker Faire Bring A Hack event. I started this on April 7th. The Faire is May 16th.
benchoffBenchoff 04/22/2015 at 22:530 Comments
The boards arrived and the I2C RTC is up and running, confirming that at least some of the board works. I'm a little hesitant about soldering those driver chips... I need a hot air setup.
If you need some instructions on setting up the I2C, here you go
