It may be possible to extrude thermoplastic starch into a hose or pipe that could be laid in the field while seeds are being planted. The extruded pipes would be biodegradable and non toxic.
At the end of each row the pipes would connect to a permanent manifold that connects to the main water supply.
Alternatively the extrusions could be pre-made and sold in rolls to be distributed in the field.
