Jeremy's voice
A project log for Jeremy The Butler Bot
A talking mobile butler robot fitted with a British accent, using Arduino components and accessories.
Austin MarandosAustin Marandos 05/02/2015 at 03:132 Comments
This isn't much of an update (since I had already programmed this before I made this page) but I thought I should share Jeremy's voice, hope you enjoy ;)
Austin Marandos wrote 07/26/2015 at 08:11 point
No I don't have a github page unfortunately, however the code is from adafruit it is a simple test code for the Waveshield located at https://learn.adafruit.com/adafruit-wave-shield-audio-shield-for-arduino/play6-hc , I haven't been very active on Jeremy since I have been busy in another country for work but I hope to continue him once I am back Good luck with your project :)
mathew.tucker.1 wrote 07/26/2015 at 03:41 point
Do you have a GitHub page with a copy of the code? I DIG the idea here!
I've been looking at doing something similar, but using voice2text as a means of giving commands to the bot. This though, is the part I've been struggling with... making it "speak."
