FTC_Tetrix_Motor_Mount.zipA zip file that contains a STL and a PRT file for a 3D printed motor mount.x-zip-compressed - 784.12 kB - 02/19/2018 at 07:17 |
FTC_Tetrix_Omniwheel.zipA zip file that contains the pieces needed for printing an omnwheel. Contains STLs and PRT files for one roller and for half of the omniwheel framex-zip-compressed - 1.91 MB - 02/19/2018 at 07:17 |
FTC_Phone_Support.zipA zip file that contains our own phone support for our FTC robot. Includes a STL file and a PRT.x-zip-compressed - 1.90 MB - 02/19/2018 at 06:38 |
FTC_Relic_4Parts.zipA zip file that contains a FTC Relic Recovery Relic, split in 4 STLs, each taking about 2 and a half hours to print.x-zip-compressed - 4.07 MB - 02/19/2018 at 06:24 |
Idler_T5_10mm_24T.zipA zip file that contains 3D models from Thingiverse, that we used to guide our T5 belts in our custom-made tank drive we madel last summer.x-zip-compressed - 67.39 kB - 02/18/2018 at 17:22 |
odometer.zipA zip file that contains our 3D modeled odometer support for last year's robot. Includes SCAD and STL filesx-zip-compressed - 6.46 kB - 02/18/2018 at 17:22 |
particle_guide.zipA zip file that contains our 3D modeled particle guide for the last year's robot. Includes SCAD and STL filesx-zip-compressed - 3.34 kB - 02/18/2018 at 17:22 |
Usb_strain_relief.zipA zip file that contains different versions of strain relief for our usb cables in STL format.x-zip-compressed - 63.22 kB - 02/18/2018 at 13:07 |
Modules_support.zipA zip file which contains two STLs. The Modules_mount is a support for any ModernRobotics electronics modules, and the Modules_base is the base for those mounts. More information in the "Details" section of the projectx-zip-compressed - 69.08 kB - 02/18/2018 at 13:03 |
120_gear_double_height.stlA double thickness 120 teeth gear, used when you don't have the money to buy metal gearsStandard Tesselated Geometry - 7.77 MB - 02/18/2018 at 12:59 |
80_gear_double_height.stlA double thickness 80 teeth gear, used when you don't have the money to buy metal gearsStandard Tesselated Geometry - 4.24 MB - 02/18/2018 at 12:56 |
Sensor_Mount_L_2_Thingiverse.STLA reinforced L sensor mount for ModernRobotics sensors.Standard Tesselated Geometry - 122.54 kB - 02/18/2018 at 12:50 |
wire_clamp.stlThis is the wire clamp we use to organise our wires around the robot, and it fits perfectly inside the channel.Standard Tesselated Geometry - 12.19 kB - 02/18/2018 at 12:48 |
Sensor_Adapter.STLA flat adapter for ModernRobotics sensors, useful when you want to screw the sensors on the Tetrix profile.Standard Tesselated Geometry - 160.34 kB - 02/18/2018 at 12:48 |
20x20_double_profile_end.stlThis is our 3D modeled double end cap for a doubled 20x20 aluminium profile.simplify3d_stl - 710.73 kB - 02/19/2018 at 06:46 |
20x20 end cap.stlThis is our 3D modeled end cap for a 20x20 aluminium profile, because in FTC you are not allowed to have sharp edges, and they are very useful when you don't want to polish every profile end on the robotStandard Tesselated Geometry - 196.86 kB - 02/17/2018 at 11:07 |
40 gear double height.zipThis is the zip archive for our double thickness 40 teeth gears. It includes the STL file, an ASM part for the double thickness gear, and the original PRT gear.Zip Archive - 1.78 MB - 02/17/2018 at 10:59 |
FTC_IR_seaker_sensor_mount_L.STLThis is the STL for another adaptor for ModernRobotics sensors. It is useful if you are very space constrained, but is weaker than other mounts I have posted here.Standard Tesselated Geometry - 119.61 kB - 02/17/2018 at 10:18 |
big_corner.zipThis is the zip archive for our corners. It includes the STL and a .PRT file (made in creo 4.0)Zip Archive - 1.33 MB - 02/17/2018 at 10:09 |
FTC_flat_IR_seeker_sensor_mount_rounded.STLThis is the STL file for the adaptor for the IR seeker. We used it for the range seeker.Standard Tesselated Geometry - 167.95 kB - 02/17/2018 at 10:02 |
