Easily Assembled Moisture Sensing graph
A moisture sensor for use in soil that measures from no to high moisture and gives LED feedback.
A short project I put together to demo the capabilities of Arduino mostly aimed at an adult non maker audience for the local faire the library held. This was a good re-entry into using the Arduino IDE and is very messy. This project page is mostly up for documentation.
  • 5 × 220ohm resistors On hand
  • 1 × 1kohm resistor On hand
  • 3 × Yellow Leds On hand
  • 1 × Red Led On hand
  • 1 × Green Led On hand
View all 7 components
