First two ready
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex 07/26/2015 at 13:142 Comments
So here are picture of the first two revion 2 PCBs soldered and in the case:
Jarrett wrote 07/27/2015 at 01:12 point
Looks good!
So you're able to connect and reprogram through USB?
Alex wrote 07/27/2015 at 12:20 point
Thanks.
Programming is via USB (or better:
over the serial port which you get through the USB to serial converter
onboard) . I use a modified Arduino Library (https://github.com/esp8266/arduino) for it.
