Third soldered
A project log for ESP8266 (ESP-07/12) Dev Board
PCB for fast development with ESP-07 / ESP-12 with on board USB to Serial converter and on board lipo charge / protection circuit
alexAlex 08/01/2015 at 16:260 Comments
Today I soldered the first revision board with battery management. it works and now I can use this for of grid operation. This board is also soldered with the switching regulator. This is much more efficient so less battery power get wasted.
On the last picture you can also see the stack up of the case quite good.
