LINX - Servo 1 Channel.viExample LabVIEW program to control servo based on boolean input.vi - 24.06 kB - 02/13/2018 at 17:41 |
Motor Holder.stlPart to hold motor still on valve assembly, keeping it from rotating.Standard Tesselated Geometry - 20.49 kB - 02/13/2018 at 15:53 |
Valve Adapter.stlPart to adapt motor shaft to valve shaft.Standard Tesselated Geometry - 27.13 kB - 02/13/2018 at 15:53 |
