3D Printed Shower Drain Replacement
Custom-shaped drain cover broke, no ready replacement at the big box stores... no problem!
From a few dimensional snaps with camera and measuring tape, I created a model in Fusion 360. So far I have eyeballed it from the photos, but if precision is required, exact pattern could be made from MS Paint. I can always sand the piece until it fits exactly. Test fitting tonight, once I manage to get it off the build plate. Result: perfect fit. Also decided to model a variant with a short pipe flange.
See on Thingiverse:
https://www.thingiverse.com/thing:2793495
ShowerDrainNoFlange.stl
Flat with no pipe flange
Standard Tesselated Geometry - 699.79 kB - 02/14/2018 at 05:30
Download
ShowerDrainWithFlange.stl
Has flange for 3" pipe, should prevent popping out and sliding around.
Standard Tesselated Geometry - 765.12 kB - 02/14/2018 at 05:30
Download
Rounded Square Drain with pipe flange v1.f3d
Fusion 360 archive source, with flange
fusion - 254.57 kB - 02/14/2018 at 05:30
Download
Rounded Square Drain v8.f3d
Fusion 360 archive source, without flange.
fusion - 182.38 kB - 02/14/2018 at 05:30
Download
  • 1
    Step 1
    Printed in ABS, 100% infill, 0.2mm layers though you could go coarser to speed up the print.
View all instructions
Bryan Williams wrote 02/15/2018 at 04:48 point
Thanks, it's quite strong at 8mm thick, confident it would support 500 lbs, and the 0.2mm layers give it a nice texture for a foot massage!
Mike Szczys wrote 02/14/2018 at 20:07 point
This is awesome!  Something I wouldn't have thought of printing, but obviously super-easy both in modeling and printing. Nice.
