Hololens Repair Notch Cutter.stl
Print this piece to use as a guide to cut notches into the strap
Standard Tesselated Geometry - 12.19 kB - 02/13/2018 at 19:49
Download
Hololens Repair A with Notch.stl
Notch method, outside bracket (away from wearer's head)
Standard Tesselated Geometry - 81.53 kB - 02/13/2018 at 19:49
Download
Hololens Repair A with Pin.stl
Pin method, outside bracket (away from wearer's head)
Standard Tesselated Geometry - 88.17 kB - 02/13/2018 at 19:49
Download
Hololens Repair Hole Punch Guide.stl
Print this piece to use as a guide to drill or punch a hole into the strap
Standard Tesselated Geometry - 19.61 kB - 02/13/2018 at 19:49
Download
Hololens Repair B with Notch.stl
Notch method, inside bracket (next to wearer's head)
Standard Tesselated Geometry - 58.68 kB - 02/13/2018 at 19:49
Download
Hololens Repair B with Pin.stl
Pin method, inside bracket (next to wearer's head)
Standard Tesselated Geometry - 83.97 kB - 02/13/2018 at 19:49
Download
