It's time to mount the back panel
HDMI mount- I've made a 2x1cm hole for the female-female connector, one end was trimmed down but this was intentional:
Mount is made using acrylic scraps and aluminum sheet, this is how it looked before trimming down:
I've epoxied 2 pieces of acrylic to make the back plate more durable near the air ventI could have used thinner ones- air vent area is now much more rigid than the other half ;)
Visible part of the back panel is made out of an old laptop, because it's not long enough I'll use two parts. Getting ready for epoxy:
And after gluing all together and trimming down:
I could do it better- connection between black plastics is not the best one, you can see it on the left side of HDMI connector; power adapter is already attached and the hole for mains cable is ready:
And the panel in all it's glory in the case:All parts in the case are on their places and connected:Wifi extension cable is made from a thin coaxial cable (removed form a laptop) with crimped RP-SMA connectors. Connectors are made for a thicker one but this one works fine- no problems with signal.As for the MCE remote- I may have to use an older OpenELEC build. I've compiled 5.0.6.0 from sources but still remote is not recognized.
If Kodi/XBMC temperature reading is correct it may be possible not to use the cooling fan after all. During the test run SoC didn't reach 45 Celsius
