• Final assembly
    Richard Deininger04/16/2015 at 12:46 0 comments
    After the testing was done and some fiddling around on how to arrange the speakers, display, Raspberry, USB Hub,.... and so on, I decided to take the first step and cut the ammunition box to hold the display.
    As you can see my cut was a little bit off,... but with an angle grinder you can't expect brain surgery precision (at least not from me).
    Then I got some motherboard mount screws, screwed them in and turned them into rivets (hammered them flat so they won't fall out)
    After some tedious drilling and rounding off the edges with a counter sink I secured the speakers with hot glue and display with Raspberry Pi on the back onto the mount screws.
    I made another hole in the back to have the option to use an external (USB) power supply instead of the powerbank.
  • Testing speaker sound & power supply
    Richard Deininger04/16/2015 at 12:30 0 comments
    Second test was done a few days later (the delivery of the speakers was late). I tested the quality and the loudness of the speakers and at the same time the drain on the powerbank.
    The PiTFT was still missing in this setup, but at this point I was not sure if I should make the player completely headless or not...
  • Testing the software and performance
    Richard Deininger04/16/2015 at 12:22 0 comments
    First I tested the installation of the Wall Mounted SqueezePlayer on my Raspberry Pi and had to update the existing skins to match my 320x240 PiTFT resolution.
