Defcon 26 Shitty Add-Ons
It's a wearable badge, for badge add-ons. It's badges all the way down.
The #badgelife of Defcon 26 will feature badges with badges! Remember the Brain Slug on the Bender Badge from last year? Yeah, like that, only we figured out the most minimal and shittiest implementation so *all* badges can have shitty add-ons.
Known I2C Addresses on Same Bus
To avoid address conflicts, known 7-bit addresses are below. If I2C is utilized on your addon, avoid these.
We recommend exposing I2C-slave address pins via test points or pins/jumpers to allow for reconfiguration in the event of an address conflict. Typically these can be changed by pulling the address pin low or high. Refer to the device's datasheet for further information.
BadgeAddress
AND!XOR DC260x30
AND!XOR DC260x18
MR ROBOT BADGE0x60
MR ROBOT BADGE0xA0 -- Using for Serial EEPROM
Mr Blinky Bling0x42
kicad_mod - 1.74 kB - 04/06/2018 at 17:51
Download
lib - 455.00 bytes - 04/06/2018 at 17:51
Download
sch - 75.92 kB - 02/14/2018 at 00:58
See BOM
Download
brd - 38.04 kB - 02/14/2018 at 00:58
Download
x-zip-compressed - 63.88 kB - 02/14/2018 at 00:58
Download
  • #badgelife DC26 shitty development board
    Zapp04/06/2018 at 20:44 3 comments
    Want to make your own add-on but all you have is a pile of through hole components and some ideas? Or maybe you're a l33t soldering machine, capable of soldering 200+ pin BGA packages to proto boards. Look no further than the #badgelife DC26 shitty addon development board.
    Of course you should know this meets the extremely high quality standards that all shitty addons are required to meet. Quality is so high, these are not tested prior to production.
    https://oshpark.com/shared_projects/GQSszwbF
  • The design of the Totem is complete
    Benchoff02/14/2018 at 01:02 1 comment
    This is a 'totem' that will hold four add-on badges as implemented in the DC26 shitty add-on standard. There are provisions for two AA batteries (optional, if you want to power them externally), a lanyard hole, and a 1x4 header breaking out VCC, SDA, SCL, and GND. Basically, it's the shittiest thing you can imagine.
    How does this connect to Badge add-ons?
    There you go. Gerbers available in this project. Also available as a shared project on OshPark: https://oshpark.com/shared_projects/uYwa5w3S
View all 2 project logs
  • 1
    Print it
    Have it printed.
  • 2
    Solder it
    Get out your iron and put the parts on
  • 3
    Power it
    Find some batteries in that one drawer that never opens because there's a potato masher or something in there.
View all 4 instructions
Sajin wrote 07/25/2018 at 16:15 point
Created shitty add-on scanner / debugger. This would print over UART all the "Friendly names" for the badges. Tries to read and write to all devices found.  https://github.com/sajingeo/b617/tree/master/gadget_test
oshpark wrote 06/06/2018 at 16:51 point
Please email drew@oshpark.com if anyone would like a batch of add-on's made for no cost.  Drew will be at Defcon and wants to make sure everyone is well stocked with fun add-on's :)
ReanimationXP wrote 02/23/2018 at 10:32 point
So obviously this is shitty, but power's a concern. I'd clarify 3v3 if that's a requirement vs VCC.. VCC is ambiguous and I suspect lots of badges will be 5v VCC.  It's also a lot harder to go back up to 5v than down to 3v3 from 5v.
Benchoff wrote 02/23/2018 at 18:39 point
As far as I can tell, most of the #badgelife badges are going to be 3.3V.  That's what we're settling on, I guess /shrug.
Also, this is the *shitty* addon. If you want guaranteed voltages and the ability to sink a set amount of current, make your own standard. This is the one where we go, 'yeah, that'll probably work.'
Adam Vadala-Roth wrote 02/22/2018 at 23:34 point
"Find some batteries in that one drawer that never opens because there's a potato masher or something in there." how do you know you've never been to my house lol
Ted Yapo wrote 02/22/2018 at 23:58 point
That's what you think...
