#badgelife DC26 shitty development board
A project log for Shitty Add-Ons
Stop calling it 'SAO'.
zappZapp 04/06/2018 at 20:443 Comments
Want to make your own add-on but all you have is a pile of through hole components and some ideas? Or maybe you're a l33t soldering machine, capable of soldering 200+ pin BGA packages to proto boards. Look no further than the #badgelife DC26 shitty addon development board.
Of course you should know this meets the extremely high quality standards that all shitty addons are required to meet. Quality is so high, these are not tested prior to production.
https://oshpark.com/shared_projects/GQSszwbF
oshpark wrote 07/09/2018 at 14:40 point
Any suggested improvements before I get a batch of 100 made to hand out at DefCon?
Current design:
https://github.com/ANDnXOR/badgelife_dev_board
OSH Park shared project:
https://oshpark.com/shared_projects/LzD8qZoG
Jan wrote 07/09/2018 at 19:33 point
Let's summarize:
1) font: comic sans?: 12/10 shitty
2) pinout right? seems so: 0/10 shitty
3) sharp edges to accidently cut yourself: 10/10 shitty
Another nice feature would be: square solder pads, so one COULD fit a few SMD passives if one wanted to...
yeti wrote 04/09/2018 at 01:48 point
Look at https://github.com/harbaum/I2C-Tiny-USB/tree/master/digispark for an irresistible USB↔I²C interface.
