SerialPlot 0.8
A project log for SerialPlot - Realtime Plotting Software
Small and simple software for plotting data from serial port
hasan-yavuz-zderyaHasan Yavuz Ă–zderya 09/27/2016 at 19:361 Comment
It's time for another release. As always screenshot first:
As you can see from the screnshot now its possible to plot each channel as a separate row. Activated from menu "View -> Multi Plot".
When you zoom enough symbols are shown to indicate data points.
Another addition is the ability to save application settings to a file. Every time the SerialPlot starts, it loads the settings from the last session automaticaly.
"Number of samples" limit is increased upon request. It was 10 000 samples now it is 1 000 000. My experiments show that, around 100 000 samples, things start to get slow. If you set it to 1M samples you are probably going to have a hard time, obviously this depends on your computer hardware. Because of that SerialPlot will warn you if you try to set it to more than 10 000 samples.
There are also numerous bug fixes.
Download Windows installer: https://bitbucket.org/hyOzd/serialplot/downloads/serialplot-0.8.1-win64.exe
Ubuntu PPA: https://launchpad.net/~hyozd/+archive/ubuntu/serialplot
Maxim wrote 04/10/2017 at 14:15 point
Really useful additions, thanks. Pls, look into discussion into the main page, some ideas here.
