Printable Electronic Components
Print common resistors, capacitors, transistors, ICs, etc onto PCBs at a cost lower than standard component manufacture / pick-and-place.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The technology is already here - we just need to optimize it! Imagine printing most of your SMDs onto a circuit board, adding your high-transistor-count chips manually, reflowing it, and then finishing it off with the through-hole stuff...
The component tolerances might not be quite as tight, but for many applications, that shouldn't even matter.
