Torque control now in place!
A project log for WEEDINATOR 2019
The WEEDINATOR project continues .... The inevitability of robots working on farms draws ever nearer ....
capt-flatus-oflahertyCapt. Flatus O'Flaherty ☠ 05/09/2018 at 16:040 Comments
When the machine was driving over rough ground the wheels would lose synch with each other and get positional errors showing on the motor drive displays. A current sensor PCB was built to override positional control when necessary by effectively monitoring the torque instead:
The machine was made to drive over a ramp under one of the wheels to simulate uneven ground and the MCU code was tweaked to get the torque balanced throughout the operation.
