As the season continues, the ground dries out a bit more and it's possible to get a much finer tilthe in the soil, which provides a different environment in which to test the machine.
Blue ropes are laid down for the machine to use as an even more accurate guide than GPS. Cameras can pick up on the rope and translate it into x, y coordinates which can then guide the machine's steering.
