Some Messy Soldering
A project log for Low Cost Wireless Home Automation and Security
This is an IoT based wireless Home Automation and Security System
sounak-ranjan-dasSounak Ranjan Das 05/27/2015 at 14:512 Comments
I know I suck at soldering but heres a pic of the relay module that I soldered. It was very tiresome job to solder all the components together.
Sounak Ranjan Das wrote 06/06/2015 at 21:50 point
what kind of wires are you suggesting?? I also found that some single core wires are very brittle.... they tend to break easily.... its better if you can give e some links to the wires you are talking about.
Ocko Kubik wrote 06/06/2015 at 21:27 point
I recommend to use thinner wires, it makes soldering easier. I also use silver coated wires for things like power buses etc.
