Source Code V1.0
A project log for Low Cost Wireless Home Automation and Security
This is an IoT based wireless Home Automation and Security System
sounak-ranjan-dasSounak Ranjan Das 05/14/2015 at 19:230 Comments
Uploaded the first version of the source code. Although all the nodes have not been tested. But tested it with one obstacle sensor. Seems to work fine. Faced some problem with the Enrf24 library. Previously I declared the structure variables globally but it was causing problem for reception don't know why. Then tried to declare them locally within the functions and copied them later to another structure. Now it seems to work fine.
Still need to work on
