// Simple KnightRider pattern to test 8 IO pins driven by the ESP-12 using Arduino IDE for ESP
// Wiring notes:
// CH_PD and RESET must be connected to 3V3.
// GPIO15 must be connected to GND.
// GPIO0 must be connected to GND prior to uploading sketch, but otherwise can be used freely
byte pattern[] = {4,5,0,2, 16,14,12,13, 12,14,16, 2,0,5};
int pinIndex = 13;
void setup() {
byte pins[] = {4,5,0,2, 16,14,12,13};
for (byte i=0; i<8; i++) {
pinMode( pins[i], OUTPUT);
// the loop function runs over and over again forever
void loop() {
digitalWrite( pattern[pinIndex--], HIGH); // Off
if (pinIndex==-1) pinIndex=13;
digitalWrite( pattern[pinIndex], LOW); // ON
delay(100);
To learn how to start writing Sketches for the ESP8266 using the Arduino IDE, see Arduino IDE for ESP Quickstart Guide
Mishel George
Misfittech
Gustavo Reynaga
Hey there! Finally found this again. Can't you use a pull-down on GPIO15 to use it as well? I'm finally getting a project started with the ESP modules and was looking for this project - thanks for sharing!
