Automatic Plant Watering System
Automated supply of water to plants using Arduino Uno, Soil moisture sensor and Flow sensor
This project uses an Arduino Uno, Micro Plastic Submersible Pump, Flow Sensor and a Soil Moisture Sensor.
The submersible pump has to be placed inside a bucket or tank of water.
Arduino Uno checks feedback from Soil Moisture Sensor to find out if the soil is dry. If yes, the Micro Plastic Submersible Pump is switched on, and water begins to flow to the plant. At a time, only half a litre of water flows into the plant before soil moisture sensor checks if the moisture level is sufficient or not. If it is still below low, the submersible pump continues to run. If however, the moisture level is sufficient, the submersible pump is switched off and the moisture sensor continues to sense and waits till the moisture level reduces to turn the pump on again.
Mike wrote 01/21/2019 at 18:22 point
Links for the roborium items have changed:
https://roborium.com/micro-plastic-submersible-pump
Flow Sensor
https://roborium.com/flow-sensor
https://roborium.com/soil-moisture-sensor
tonmoyb157 wrote 10/16/2016 at 05:22 point
 any free code
Juanduino wrote 07/30/2015 at 11:36 point
Tjeck out this ! https://hackaday.io/project/6995-icndy
When you get it online, it could be used with our UI. Just need do integrate some kind of Key Gen for users to register devises.
Robert wrote 05/10/2015 at 10:59 point
want make it an IoT-Device, that you can monitor and controll it from the internet ?
write me: info@euerdesign.de
Jasmeet Singh wrote 05/17/2015 at 11:20 point
Yeah I'd love to. What do you suggest?
sbi.gaijin wrote 07/04/2015 at 00:24 point
An ESP8266.  You can get rid of the arduino completely (and using the Arduino IDE for the ESP8266 [https://github.com/esp8266/Arduino] you can still use your arduino code).
James Newton wrote 05/08/2015 at 19:53 point
Code?
Jasmeet Singh wrote 05/09/2015 at 11:51 point
You can download it here- http://jmoonmaker.space/public/automatic-plant-watering-system
Click on button just above the images and use Social Pay to download code.
zakqwy wrote 05/18/2015 at 14:34 point
Social Pay? hmmmmm...
